I think you mean fluorescent tube, not neon. They might light with DC, but their lifetime will be seriously reduced, I wouldn't recommend it.
Normally, these lamps are voltage-independent: their actual voltage is generally below 100V, and their outside operating voltage is set by the ballast, either conventional or electronic.
That is the part you should change to change the voltage.
If it is included in the lamp, it depends very much on its implementation: some will only tolerate the exact type of current and voltage, others will accept DC, and /or a wide of input voltages.
Can you provide additional details?
Actually, yes, I've been a bit unclear. I'm pretty sure I mean neon, however not your usual neon pilot light. I mean Aerolux glow light bulb (or, more likely, a clone of that) like so: Aerolux Light Corporation - Wikipedia, the free encyclopedia. Given the age of their existence and manufacture, I am guessing they're working directly plugged into 110VAC. I suppose that like any other Neon bulb nothing is stopping me from using them with 110VDC, except that only one of the electrodes will glow, I'm not too sure if that'll have negative impact.
I am pretty sure it will, better stick with AC. To avoid most of the useless dissipation of a resistor, you could use a capacitive dropper as a main ballast.I suppose that like any other Neon bulb nothing is stopping me from using them with 110VDC, except that only one of the electrodes will glow, I'm not too sure if that'll have negative impact.
A small resistor would probably still be needed to avoid effects of negative resistance. You could try with two 1µF/250VAC X capacitors in parallel, and a 100 ohm/1W series resistor.
Not necessarily, it depends on the type of discharge. But you can check the presence/value of such a resistor, it will provide useful information for the 230V conversionSlightly-off-topic: I guess they come with a current-limiting resistor integrated, if they're made to directly go in a 110v socket?
Watt-less Power
Why use a transformer/resistor?
Use a 470nF 250Volt class Y capacitor in series with the lamp. That will give you approximately 5Watts of power at a reduced current.
This method is nicknamed 'Watt-less Power' as there is no loss and no heat given off, wasting power.
Television and audio equipment, over the years, used this method to produce a Standby voltage to run the microprocessor and basic memory.
a safe way for experimenting:
if you have one 220v / 12v plus one 220v / 24v trafo, connect them back-to-back
220v / 12v -> 24v / 220v out comes 110v isolated from mains
another not so safe way:
if you have a 220v trafo which has a 110v+110v primary it could be used as auto-transformer not (!) isolated from mains though
I finally got a bunch of the bulbs, all in workable condition. They do seem to come with a current limiting resistor integrated, as the socket will slowly heat up with time. The actual bulbs are just barely warm. For now I am testing them with a 110v isolation transformer that I got.
- Power Supplies
- Simplest way for low-VA 220V->110V ?
