hey, I have a few questions that seem so basic, I just wanted to be sure of myself. First, when calculating the power dissipated by a rectifier diode (Schottky), for full-wave rectification, is it simply Vf * current consumed by the load for each of the four diodes? Here's an example:
Is this the same, or different power dissipated for two diodes in FWCT, i.e:
Also, what is the purpose of a heater center-tap on a tube? Does this come into play for tubes that can be operated at either 6.3V or 12.6V, or in the CT irrelevant in this case.
Thanks!
Thanks!
