Simple Ohms law question
Joined 2003
I've always seen it as V=IR.
I've always thought about it as R=V/I (resistance is defined by the ratio)
But I've been thinking, is it more accurate to say R= (change in V) / (change in I) ?
It doesnt make a difference if the V vs I curve is linear and goes the V=0 and I = 0
Any other kind of curve (tube transfer function, transistor curves, diode curves, etc.) and you get different results.
Is it more accurate to say R= (change in V) / (change in I) ? Any other kind of curve
Yes, for a nonlinear device this is the incremental (or differential) impedance, the slope of the tangent
to the V vs I curve at the operating point, or z = dv/di. This is in general different from the static resistance,
except for perfect resistors. https://en.wikipedia.org/wiki/Electrical_resistance_and_conductance
Yes, for a diode you can only talk about the dynamic impedance,
as its not a resistor it does not follow ohms law, in any sense.
Generally you'd be talking about a devices transconductance variation
rather than the somewhat misleading dynamic resistance concept.
rgds, sreten.
It's not a simple question. dV/dI being "more correct" is a false concept.
More generally V/I=Z, but once you get into things like tubes and transistors you aren't talking about a simple 2 port passive linear device anymore.
