Simple Mirror Type PreAmp with Low Distortion
This thread was move to this sub-forum with the advice of a member.
This project had evolved from schematic to PCB fabrication.
A sample order of the PCB will arrive on Dec 22 if there is no heavy snow to block the delivery from UPS.
Here is the layout of the circuit board:
  • 63307-B btm.pdf
Jen-B,
The attached schematic drawing shows channel 1 of the stereo preamp. The voltage regulators and rectifiers are shared by both channels.
If you draw a horizontal line across the schematic, the lower portion resembles a mirror image of the upper.
Other designers might called it complementary mirror because n (or p) is complimented by p (or n) in the other half.
I called it mirror for simplicity.
  • 63307-B sch diy.pdf
