Hello all,
I am currently building (cobbling together) a hybrid integrated amp.
The tube pre-amp board requires ~12v AC
The amp board (Tripath 2020) requires ~12v DC
I currently have:
- 110/120vac-to-12vac transformer rated at 3.33 amps
- 110/120vac-to-12vdc transformer rated at 2 amps
It all works quite well during testing (see photo), however I would like remove the DC supply and implement a simple rectifier between the 12vac supply and the amp board.
I have read and understand the theory of a diode bridge and output smoothing. Diode bridge - Wikipedia, the free encyclopedia
I have a box full of spare parts with all kinds of the square metal bridge rectifiers and capacitors.
Is it as simple as hooking the 12vac leads to the AC terminals of the bridge rectifier and then connect the load to the DC terminals, with a large capacitor in parallel?
I currently have:
