Just a general question on these caps. Is there another name commonly used for silver mica? Can't find any in the Digikey cat but I see polyester and foil, metalized ployester etc. Thanks in advance
Hi Doctor ;o))
No, not that I know of, but I know that both Farnell ( http://www.farnell.com )and RS Components ( http://www.rs-components.com ) have them, if not on stock, they can deliver the next day.
Pass DIY Addict
Joined 2000
Silver Mica Caps
The ones I found are made by Cornell Dubilier and distributed by Newark Electronics. If these are parts for the Pass a40, I just updated my list of parts and suppliers in your "Solid State DIY" thread below to include these. The changes are mostly to consolidate suppliers so I can place a minimum number of orders and receive what I need. Still haven't started building yet - I have a few other "projects" to wrap up first.
Eric
Eric
Hi doktor ,
I don't know if digikey sells small quantities of them. If you logged in EBAY and search for 'mica cap.', you should be able to locate more than you need.
BTW what values are you looking for? I had quite a stock for them.
doktor said:silver mica? Can't find any in the Digikey cat
Really?
Search for "capacitor" then click on the lnk to "Mica and Teflon"
I'm not sure doktor will have been waiting 5 years for the answer.
His last post was on 06-03-2002. 😀
Wow, 5 years. I feel pretty stupid. I really need to look more closely before responding to some of these posts. I guess I'll blame the person who revived the thread.
Yeh, that would be me. I don't know how I dig this up. MY usual action will be looking thru the first few (probably 2-3) pages of the 'solid state' menu and see if there is any new or newly replied post that I might be interest to go thru. Sorry that I did not look at the date of the last post. But somehow, someone did the same thing as I had. Ha.....
just to prove that the search facility is used and even works.
Well for some it may. I have never yet found what I needed, found lots of other (very) unrelated threads and wasted lots of time.
My new target should be to learn how to generate the correct searches to enter into the fields.
You're not alone there Andrew. Sometimes I don't feel quite right checking the 'searched' box when starting a thread, but I can't reasonably do much better.
<threadhijack>
The best way I have found to search is to use Google with "site:diyaudio.com" at the end of my search string.
</threadhijack>
</threadhijack>
There is always pros and cons. The search function should mean good but sometimes it does bad. You seach for a certain key word and it returns you a thread that has 6000 reply posts (sorry bra, you are the man). How are you going to find you 'needle in that hawstack' ?
Sorry for continuing this OT trend..
bigpanda: Select the "Show results as posts" option instead of the default "Show results as threads".
- Design & Build
- Parts
- silver mica caps
