Does anybody know where to find a silent (quiet) 3PDT momentary switch?
In other words it shouldn't make a click noise when pressing it.
Switchcraft (!) makes leaf switches that are available as momentary multipole two or three position and don't click last I paid attention. They use crossbar contacts capable of reliably switching low audio levels. They are not cheap!
THAT ^^^^^^^^It's not the switch that makes noise, but the circuit design, unless it's dirty somehow.
Yes,definitely.Is this switch actually in the audio signal path?
In one position it IS the Audio Path.
But way to avoid clicks and pops is NOT having any DC voltage difference between contacts, hence no jumps.
I like how people aren't sure whether the "click noise" OP refers to is a mechanical noise or one that affects the analog signal.
Me too... just too much missing context to see it any other way (IMO).I read it as meaning mechanical noise, but he certainly could mean the other way.
If a multi-Pole switch does not CHUNK, then it is liable to connect the poles a millisecond or two apart.
Why not a single-pole plus electronic switching? Relays packed in foam?
I meant mechanical noise. The click sound a switch makes when operated not an audible electronic 'pop'. I do not wish to use relays.
It is actually for a very simple audio switch box to compare sources without hearing me making the switch between both. I already did this with a 2pdt switch but this one makes a clicking sound. I want to switch grounds too so I was looking for a 3pdt switch like this that operates silently:
https://www.musikding.de/media/image/product/43/md/3pdt-footswitch.jpg
Thanks Silverprout. Very good suggestion. I just ordered these though:
2 PCS PBS 24 312SP 4A 125VAC PCB Terminal OP Momentary OP Type Zwart Gitaar Effecten Pedaal Stompbox Gitaar onderdelen-in Boot onderdelen & Accessoires van sport & Entertainment op AliExpress
I think they will do the job.
- Design & Build
- Parts
- Silent (Quiet) 3PDT momentary switch?
