Hallo,
I found a pair of Siemens Sikorel 105 LL, 22000uF, 63V, 105 degrees, +30/-10%, model B41570-A8229-Q in a local shop. They are new and dated 1990. I'm planning to sell them, what do you think an appropriate price would be?
AC
AC
I've seen that the correspondent 'Epcos' caps are quite expensive and I wonder if I could aim at a similar price or I should drastically reduce it because of the age.
The actual capacitance is probably different from the nominal one because of the age, but it should be possible to 'reform' the caps. I do not know whether ESR or other values change after 20 years of storage.
Any hint is highly appreciated.
Or if you're interested, please make an offer.
AC
AC
