I recently aquired a tube amp relic for $50 off ebay . the relevant parts of the description reads
RCA single ended tube amp removed from a console. IT has had resistors changed to modern types and the cathode bypass on the outputs raised to give better low frequecny pass. All valves are strong. This soulds fantastic. Great warm single ended sound sought after by audiofiles. The inputs are the older RCA type, three pin. I did not convert the inputs to any jacks, the buyer can install the type of inputs he desires. There is no hum. The line-up is: 12AX7, (2) 6BQ5 and 5Y3GT
I find that one channel doesn't work, though the input (1) / output transformers (2) appear okey. the other channel sounds very nice
It's from a console and therefore not much of a looker though i could re-paint the chassis and get it to a relatively respectable state.
beyond that, i have 2 options:
1. try and troubleshoot the faulty channel
(any hints here as how to proceed)
2. rip out all the electronics and re-build it. any suggestions on schematics based on the tubes i have? i wouldwant it as simple as possible (no balance / treble / bass / input selector)
this is my first foray into tube electronics and i am still reading up info.
thanks in advance
[IMGDEAD]http://abacus.sj.ipixmedia.com/abc/M28/_EBAY_5ea35c7bec819016937e166cd1/i-1.JPG[/IMGDEAD]
thanks in advance
