Setting for AK4490 in parallel(hardware) mode
I'm designing a ak4490 board that work in parallel (hardware) mode and there are something i need helps:
Pin 2 PDN in datasheet:
Power-Down Mode Pin
When at “L”, the AK4490 is in power-down mode and is held in
reset.The AK4490 must always be reset upon power-up.
does that mean i need to make this pin Low (reset) when start then High?
Thanks!
