Hello all!
First off I'm a "First time poster, Long time lurker", so be gentle.
At some stage in the future, I'm looking at building some DIY 3-way (L & R) speakers and hooking them up to an active crossover so that I can play around with x-over points, EQ, phase, etc. I think I've sorted out most (?) things to do with the actual speakers, but what's stumping me at the moment is the chain of devices. That's where I'm hoping someone can point me in the right direction.
I *think* this is how it goes;
Input source(s) > AVR > X-Over/EQ > Amps > Speakers.
Is that correct?
Another question would be; going through the x-over and amps, would the AVR still control the overall volume? Some amps seem to have a seperate volume control (no names spring to mind right now). I'm also wanting to be able to turn the AVR on, and everything else fires up; is it possible to make this happen if the component does not have a 12V trigger?
And finally, for bonus points, could you name a few 3-way x-over/EQ systems? I'm aware a lot of people use the Behringer, I'm just after some other brands/models that I can look into. I read about someone using a computer as their x-over earlier, is it possible to have a '12v trigger' like effect on this when I powerup the AVR?
I thank-you for any input whatsoever. Also if this perhaps isn't the right forum board, could you please let me know where to go.
Wai
Is that correct?
Wai
