Hello,
I'm looking to build a sub for my music only system, and have pretty much decided on a Rythmik 12" servo system, based on favorable comments here and elsewhere. I'm trying to keep the enclosure as small as possible, as in preferably not more than ~1.5 cu. ft.. The Rythmik 12" standard takes 2.0 cu. ft; Brian at Rythmik says they no longer produce the compact version, and pointed me to the GR Research 12" servo sub which apparently fits the bill.
http://www.gr-research.com/index.asp?PageAction=VIEWPROD&ProdID=139
However, that sub has a foam surround, which I'd like to avoid b/c of foam rot. (I didn't know they still made drivers with foam surrounds!)
So here's my question: what would happen if I take a Rythmik 12" standard and put it into a ~1.5 cu. ft. box? Is it just a matter of losing SPL (not particularly important to me; I don't listen to music at party volumes)? Or will it be terrible and should I just get the GR Research sub?
I can model these things with the spreadsheets for sealed boxes, but since this is a servo design, and one where the Qts is controlled by the amp rather than by the enclosure, I'm not sure how to model it.
Thanks for any suggestions.
