Hey everyone, I'm currently working on my senior project and want to organize my project on this thread so I can hear some feedback and get some guidance.
My Senior Project Specifications:
• An original 1957 Fender Deluxe Amplifier will be hand built.
• A fully functional equalizer pedal will be engineered.
• The Equalizer Pedal will be powered by batteries
• A push button or switch will turn the foot pedal on and off
• A minimum 3-band equalizer will be used on the pedal
• Low (Bass) center frequency band: 78Hz (10% tolerance)
• Middle center frequency band: 1.15kHz (10% tolerance)
• High (Treble) center frequency band: 7.8kHz (10% tolerance)
• Equalizer Control will vary up to +/- 15dB per band
1957 Deluxe has been built. See below (Enjoying my oak cabinet. First woodworking project I've done by myself.)
The enclosure for the bandpass filter is mostly done. I have an on/off switch tied to an LED and a bypass switch on top. I left room for more bandpass filters and other modifications while the circuit is being modified. I'll probably end up making it 7-bands.
My circuit is simple at the moment. I have multiple first order active non-inverting bandpass filters in parallel. Outputs are connected to a summing amplifier. I used information from my textbook but it's similar to this website (Op-amp Filter - The Active Band Pass Filter) My theoretical circuit is working in Multisim. I'll hopefully verify my breadboard circuit with an oscilloscope later this week. It does seem to be working when plugged into my amp for now.
So here is where I am at the moment. Assuming that my breadboard circuit works, my non-inverting filter can only give me a positive gain. Specifications have to be +/-15dB for each band. What would be the simplest way to implement this to my circuit? Advise or a point towards useful information would be appreciated.
A thought I've had is to use an inverting bandpass filter for each band somehow but the gain would be multiplied by the non-inverting filter if it's in series with the non-inverting filter. This would still only give me a + or - gain only, not both. I've had other ideas also but I'd like to hear what other people think.
I'll keep updating this thread as I continue my project for other audio enthusiasts. I'll even post a YouTube video of the finished product when it's done. I have all my receipts, information used, calculations, and problems in my notebook.
