Semiconductors for Sale : Schottkys/MSR's/MJL transistors /MosFets/Regulators
After a change of heart I have decided to scrap a few projects.
I have the folowing for sale:
Quantity Part Description
10 LM337BT 1.5A NEG. Adj. Regulator
10 LM317BT 1.5A POS. Adj. Regulator
6 LM350T 3.0A Pos. Adj Regulator
5 Fairchild FQA12P20 12AMP 200V P Mosfet Device
5 Fairchild FQA19N20C 19AMP 200V N Mosfet Device
5 Fairchild FQP3P20 3AMP 200V P Mosfet Device
5 Fairchild FQP4N20 4AMP 200V P Mosfet Device
8 MBR3100 3A 100V Schottky power diode
10 MUR460 4A 600V power Diode
10 MBR20200G 20A Schottky 200V power diode
10 MSR1560 15A 600V Ultrafast /soft recovery diode
10 BC490C small signal transistor TO92
10 BC550C small signal transistor TO92
10 BC560C small signal transistor TO92
10 MJL0302A 180W 15A 260V 180W PNP Transistor
10 MJL0281A 180W 15A 260V 180W NPN Transistor
5 MJL1302A 180W 15A 260V 180W PNP Transistor
5 MJL3281A 180W 15A 260V 180W NPN Transistor
5 MJL4302A 180W 15A 350V 230W PNP Transistor
5 MJL4281A 180W 15A 350V 230W NPN Transistor
Small Power Diodes/Schottky 4 Amps and under are $1 each
(Take all 18 for $10)
Large Power Diodes/Schottky >5Amps are $1.50 (Take all 20 for $20)
Regulators are $1 each (Take all 26 for $15)
MosFets are $0.75 each (Take all 20 Mosfets for $10)
Transistors (TO92) are 0.50 cents each (Take all 30 for $5)
MJL Devices are $2 each (Take all 40 for $60)
If you want the whole lot then it would be $100 + shipping
Note : I am waiting for the MJL devices to arrive as I only ordered them last week.
Let me know if you are interested.
Of course all parts are new.
I do have a bunch slightly used MSR1560 where the leads are bent to fit into standard DO-41 (1N4004 for example mounting on board). I will sell those for $0.50 each.
I also have some used Sanyo OSCON available for $0.50 each as well. Most ly like 4.7uF 25V range to 22uF 25V or so.
I made a few mistakes on the prices of some of the items.
So I decided to repost the whole shootin' match.
Large Power Diodes/Schottky >5Amps are $1.50 (Take all 20 for $25)
MJL Devices are $2.50 each (Take all 40 for $75)
If you want the whole lot then it would be $110 + shipping
I have a few more items to add:
8 (Qty) Slightly used Sanken FP1016 Ouput Devices 180V 70W 8A Darlingtons
8 (Qty) Slightly used Sanken FN1016 Ouput Devices 180V 70W 8A Darlingtons
Sell these for $25 for all 16 devices
or $2 each.
Thanks,
Dan
Everything Sold except the following:....
5 LM350T 3.0A Pos. Adj Regulator
10 slightly used MSR1560
Refer to new add titled: Capacitors & V. Regulators and Power Diodes for more details......
