In addition to the JFETS I assume I also need these to complete the F6 kit?
"4 - IRFP240
4 - 5.1V Zeners"
These are currently on backorder on the DIYstore.
Are there other, external sources for these or should I just wait ?
Confirming I need both the JFETs and these semi conductors ?
thanks
"4 - IRFP240
4 - 5.1V Zeners"
thanks
Since the Mosfets really don't need to be matched in an F6, you could order what you need from another online source, such as Mouser or Digikey. You can also use 6.2V Zener diodes or 6.9V LM329 voltage references (not a nice drop in footprint, but it works).
thank you- do you know what exact specs I should ask for when ordering elsewhere for both the MOSFET's and the Xeners?
The F6 Illustrated Build Guide will be your best resource for this and other component related questions.
- semi conductors for F6 kit
