I am just about to finish my Seas Bragi speakers as seen on this link:
BRAGI
Which integrated amplifier would you recommend to run these speakers?
I was looking at Primare i22, Simaudio Moon 220i, Musical Fidelity M3i
Any other suggestions? I would not spend to much money on it, so a second hand amp is also an option.
BRAGI
Looking at the specs and measurements of the speaker, all of the amps you've listed are OK to drive them, or any decent integrated will do what is able to drive low impedance loads. Its minimum is around 3.5 ohms, and the impedance curve is not too tough, so you can look for similar secondhand ones from the better Rotels, or NAD-s, if you don't want to spend too much. A few alternatives (but very good ones) from an even lower price range are the Denon PMA 1080R, and Harman Kardon PM 655Vxi - those are very well built and nice sounding units for their price.
what about Rega Alex-R?
I am also a little bit confused regarding the low impendance loads. As you mentioned, minimum impendance according to measurements of the speakers is about 3 ohms. Could this be a problem with any of mentioned amps?
However, my main goal is to have tight and well controlled sound also from 100 to 400 hZ where the lowest impendance is seen.
