Searching for Part Number/Manufacturer/Supplier info for Plug Connectors used in Eden Bass Amps
Does anyone here know where I can source the plug connectors shown in the attached pics of my Eden WT-1205 bass amp?
Thanks.
MEASURE pin to pin separation.
Techtool's suggestion is a 0.1" pitch connector, most commonly used at signal and low current applications; I suspect it's a higher power rated 0.156" pitch one with much thicker pins, but again, measuring rules.
Looking again, those are IDC (insulation displacement connectors) : wires are not soldered to pins but pushed into them with a special tool (or a small flat screwdriver blade and some muscle).
Sharp edges cut through insulation and grab wire metal inside.
I know them only in .156" pitch .
