SE with the KR300BXL from KR Enterprice
Ralph,
the KR300BXL is the best 300B avaiable IMO. It rather sonds like 45 than like a 300B while having much power.
The amp schematics look reasonable to me. Just one objection: this is a single ended amp which is no constant load for its PS.
A CLCLC filter for B+ certainly has a good static filter effect but on load changes it shows a step response taking eternally for coming to rest.
Suggestion: download PSUD II and simulate your power supply. You will see that a simple LC or CLC filter responds much friendler on load changes.
Ralph,
this second one would rather be my choice. Although methinks with a 6SL7 a SS constant current source will work better than a plate choke. The 6SL7 has a plate resistance too high; the choke's inductivity might be too low to give you a proper lower bandwidth limit.
I would replace the Jensen coupling caps by SiemensEpcos MKV 25839. By any means! And for the 6SL7, i would try to get my hands on a vintage redbase RCA 5691 or vintage metal base Sylvania 6SL7.
