JonSnell Electronic said:
The formula shown is a standard formula for all transformer coupled valve amplifiers. The dB level changes with the cathode resistor value but most driver cathode resistors tend to be around 470R.
So to put it in one sentence: the formula shown is a "standard formula" for all transformer coupled (?) valve amplifiers with negative feedback returned to a 470R cathode resistor in the first stage. For all other amplifiers you need a different formula, the correct formula, the general formula. And, of course, whether it gives you 20dB of feedback depends on the open loop gain of the amplifier - which also varies quite a bit from one design to another.
So perhaps we should say that it is a "standard formula" which applies to just a small subset of all valve amplifiers, and should otherwise be ignored?
