Assembling a cabinet now and I've noticed that one of the glued bracing panels has a hairline gap along part of its length where it doesn't quite fit flush with the cabinet wall.
There seems to be a general reluctance to use any screws in speaker cabinets and to go for a "glue-only" approach when it comes to cabinet construction.
Would it be okay to put a drywall screw in the bracing panel so it contacts the cabinet wall and thus reduces a possible source of vibration at the hairline gap?
Also, to eliminate any possibility of the screw eventually becoming loose, should glue be injected in to the screw hole before the screw is screwed in good and tight?
Thanks for any suggestions!
