Schematics for Krell KSA200S
Sounds like you have have a thermal overload / DC voltage on output issue. You need to check all the Power transistors and also reseat them on the Heat sink with new washers. The old washers become brittle after 20+ years of use. You can also measure the DC on the Output Relay to see if the clicking happens when the offset voltage reaches a certain limit.
