I need help with the detailed schematic diagram for Tascam 22-4.
I cannot find it and maybe anyone can help me.
I have a problem with one channel and the defect is on Rec/Play PCB. I need the detailed schematic diagram.
I found one on Elektrotanya but is not a detailed one.
Thank you for your help.
The info you need should be here, you will need to create a (free) account
Tascam 22-4 - Manual - Tape Recorder/Reproducer - HiFi Engine
When I switch the PCBs (CH1 with CH2) the defect is moving to. So the problem is on this Rec/Play PCB CH1
Compare the two boards ... you have a good one, so use it to get readings to troubleshoot the other.
Yes, most probably but my country is banned on hi-fi engine due to some users.
Please, if you have an account please download and send me the file.
Thank you
- Analogue Source
- Schematic diagram for Tascam 22-4
