SBC with 2xI2S boards ? (potentially ODROID C1)
Hello,
Would you have identified some SBC (Single Computer Board) with 2 x I2S outputs ?
The Odroid C1 uses the Amlogic S805. From the S805 datasheet, I see:
Audio Decoder and Input/Output
- Supports MP3, AAC, WMA, RM, FLAC, Ogg and programmable with 5.1 down-mixing
- I2S audio interface supporting 2-channel input/output
- Built-in serial digital audio SPDIF/IEC958 output and PCM input/output
- Supports concurrent dual audio stereo channel output with a combination of I2S+PCM
It is not very clear to me if this board could play for audio channels in parallel.
Did somebody experienced this
Would you have identified some other SBC with similar features ?
Best regards,
JMF
