can somebody help me to build speaker enclosure for this driver
SB Acoustics SB10PGC21-4 - 3" Full-range
because I can not figure it out by myself. I tried winisd and some online plans but somehow it didn't work well. i want to keep it simple because this is my first build (check img link).
A large sealed box seems to be the best, a 50L sealed gives you a reasonable respone to 75Hz (F3), and against a wall to 60Hz (F10). So you will need a sub for a full response.
But these are drivers i would rather use in an OB with a woofer. But they are certainly not fit for ported speakers. High qts and high fs point me to that. With a large sealed one, it can work. A small sealed one give a peaky response on the low end, and moves it to 100Hz
Hi, I tried simulating this driver in WinISD, green is 6 liter ported tuned at 60Hz, and purple is 6 liter sealed. Tuning at 60Hz gives ~4dB bass boost, and this looks to be the flattest compared to other frequencies I've played with.
Question:
- Is it a reasonable tuning? Somehow I calculated 0.707*Fs and indeed it seems the flattest.
- Will it sound natural?
Port tuning, I modified Tony Gee's 103 style, inspired after reading 'Meet the Fonken' article by Dave. Port is slim and as wide as the inner width of the enclosure. Impedance graph shows a small peak below the resonance peak, which according to the article above, indicates a near-aperiodic nature of the enclosure.
Any thoughts, Gents?
Thanks for your time and expertise.
Question:
