Some of us actually prefer the way the XT25 sounds specifically because of the lower amount of energy it throws out off axis. Then the lower intensity of early reflections that results in.
What your room is like and your personal preference towards how you like things to sound will determine if you prefer something like the XT25 or not.
Not to me.
What I specifically don't like about it has everything to do with the suspension (or rather it's lacking suspension) - generating resistance and damping at extremely low excursion. And
most of that objection relates to freq.s lower than 5 kHz.
To an extent I'm also not fond of the Mms and how it lacks a bit of image "density" relative to a more standard dome (..again, below 5 kHz).
Note: I don't like the "dimple-dome" tweeters from SB either, though almost exclusively because of the suspension's "stiffness". (..not the amount of Mms, at least in relation to the larger diaphragm tweeters.)
On the other hand I do like the Scan Speak D2604/ 833000 (..and presumably the Peerless version as well). Still not as good as a good standard dome with respect to mechanical resistance, but it's a much better compromise overall (both subjectively (IMO) and objectively) - and it's also better in a waveguide than a standard dome.
