SACD playback on Marantz UD 5007?
I tried to play sacd musc on marantz ud5007 through 2 ch analog output to marantz 7007 receiver analog input, but no sound ( CDs no problem ), while through the HDMI, it's ok.
Checked the setup of the player, switched "bitstream" to "pcm", sacd can go to the receiver via analog output, and no problem with HDMI.
Now I left the setup to pcm, everything seems ok.
I have a question, is bitsteam mod able to go through the analog output? which one is better between pcm and bitstream?
Thanks.
