The IRFP064N is generally a good substitute. Seankane has probably repaired more of these than I have. Maybe he can tell you what works definitively.
The clamp has been heated to a point to where it's probably lost its temper. It will have to be straightened if you can't find a replacement but won't be as strong as it was. Install it on the regulators or something that doesn't dissipate a lot of heat.
the insulators is ugly but good and all resistors are good at 10 ohm's but the one from the fried fet at 136 ohm not good.
I have never had on of these in for a power supply. It's always been little things like op-amps and such. I wouldn't be afraid to run IRFP064N FET's in this amp with either 10 ohm or 47 ohm gates.
I have used this FET as a sub in many Rockford amps with great success.
Make sure you change the drivers as well regardless if they test good. Cheap insurance.
Do you have any shorted outputs?
Thanks for your feedback that's good to know that they will work I already ordered them and new 10 ohm @ 1% resistors now for the outputs have not even looked at them yet I need to.
No not yet I am going to do that on Monday should I use something different from the MPSA06 & MPSA56 ?Did you order the power supply FET drivers?
There is no real advantage of using different transistors.
Do you have a scope?
The way seankane ask his question that why I asked and for having a scope no
There's no positive/negative rail voltage. The amp has a single rail and it's driven positive or negative as needed. You have to measure across the caps or the rectifiers with a meter to measure the rail voltage.
The actual rail voltage isn't regulated.
I would expect 80-90v across the rail caps.
update replaced U21 it came out of protection plays fine. Thanks again for your guy's help.
- General Interest
- Car Audio
- Rockford Fosgate Type RF X6
