I'm sorry but I don't have it. Unless yours is missing or physically damaged, it can probably be cleaned. On most of the older Rockfords, I'd much prefer to see it run in 4-channel with y-cables than 2-channel.
I hear you there but the has internally failed the two clips that inside the switch has pretty much disintegrated causing static and fade in & out of the rear channels. I have removed the switch and put jumpers in it's place for right now and fine but I would like a switch back in its place.
