Rockford Fosgate Punch 200a4
They are shorted across all legs ..
On this series of amps the IF3205's will work in the power supply correct??
IF so what gate resistors should i use??
I have 3-4 of theese amps here tha i bought from a friend and all have blown supplys ..
Some have 100 ohm gates some 10 ohms
Also do you have a good part number for the source resistors for the outputs?
punch 200a4
Did a search on the punch 200a4 and came up with your thread.
I am currently working on a RF punch 200a4. Was wondering if you had a schematic I could get a copy of. This one I have is missing D8 on the circuit board and I need to find out what it is. Im pretty sure it a rectifier.
Thanks for any information you can give me.
