Rockford Fosgate Prime R1000-1D
The power supply fets failed in this amp The driver for the fets also failed..
It is a 6 pin suface mount transistor Board Location Q7 which the Schematic says the part number is C2045E5 I cant find that anywhere..
Does anyone know what the part number is for the driver or what i can use??
  • power.pdf
I too can't figure out this ampifier. It draws current with just b+ and ground. I'm thinking diodes failed in numous places as all of the main transistors are not shorted not open. All resistors seem to be in tolerence. Any help anyone can give me I would greatly appreciate it.
I get like an intermediate power up where I can see drive and then just off. I can't seem to figure it out. It draws current then normal to off. I kind of haft to remove power then power a few times and it has a show of life and I can see a drive wave start to build then as the rail voltage increases it just shuts off.
