This amp will Power up and play clean audio for about a min then it will burn all 4 bias transistors Q105,205,305,405 ..
After it burns them I get full rail voltage measured directly across WA h speaker terminal for all 4 channels ..
I replaced them 2 times now and the amp will play clean audio after a min all 4 of them burn again so all 4 channels have excessive DC on the outputs ..
Everything tests good in each channel..
Any ideas on what I'm missing here ?
I have -12.18
And it looks like the positive regulator has failed I have 26 volts on pin 8 of the opamps
