Rockford foagate 201s will not power on.
Rockford fosgate 201s will not power on.
Any guys here anymore? There used to be a wealth of knowledge, but i have not been here for quite a few years.
Trying to diagnose a non functioning amp.
Input power is 12.95v
Tl494 voltage is as follows.
1. 0.00
2. 4.41
3. .06
4. 0.00
5. 1.46
6. 3.26
7. 0.00
8. 12.20
9. 7.46
10. 7.29
11. 12.20
12. 12.20
13. 4.83
14. 4.83
15. 4.83
16. 0.00
Gate and drain of both power fet's are both 12.92
Resistors look to be in spec.
Its been a lot of years since i have done this so thats about all i know to check.
I do have the schematic and most the parts to change anything, and the skills to do smd.
Anyone with guidance?
Do you have any shorted outputs? IRF540/IRF9540
Measure from gate to source with your meter. If you find a shorted one or more clip the legs and then power up the amp.
If there is shorted outputs, check the gate resistors and source resistors for the outputs.
If any of the outputs are shorted it will cause what your experiencing. If you have any open source resistors you will likely have protection circuit damage as well.
Also when ordering new outputs for the amp order the non N version
The IRF540N and IRF9540N will not work in this amp.
Order the IRF540 and 9540 and like he said also check the source resistors to see if any are bad before placing a parts order it will save you time
Not sure without looking at the data sheet.
I have used them in repairs using 540N and 9540N and had no problems.
I have seen problems with using 540N and 9540.
I would get the non "N" versions of both. Order from Mouser, Arrow, or other reputable distributors.
Well, i had already ordered parts before i saw Jason's comment about the N's. Of course i got 540n and 9640n because they were a bit cheaper.
They showed up today, just put them in a bit ago and the amp works and sounds good.
Thanks again for the help.
