Rockford 401s repair question, and update.
now that i have the transformer removed from the amp, can i test it with a 1.5 volt battery for shorts, it all looks good now that i got the baked glue stuff off it.
I was to much of a sissy to try to power it up even with a current limiter. I wanna postpone the noob smoke, pop, and sizzle as long as possible, not to mention replacing the parts I just replaced.
I replaced the irfz44's Q6,10,11,7. The 100 ohm(R36,19,20,45) resistors on the way to the (q5,2,1,4)driver transistors are all fine. I havent checked the control ic, yet because not powering this up just yet.
Is there anything I am missing, or doing wrong so far?
I don't know how you would test with a 1.5v battery.
It's best to test the transformer in the board because simply moving the terminal windings slightly can break the short and make it appear that the transformer is OK.
With a proper current limiter and the transistors tightly clamped to the sink, there's virtually no way to damage the new parts.
Power it up with the remote and ground only (no B+). Measure the DC voltage on the gate legs of each of the power supply transistors. They should all read ~5v.
Why do you think the transformer is defective?
The adhesive/glue was all brown and nasty burnt looking. All the other ones I have seen looked clean and and nice. Now that i cleaned it off it looks fine, no bare copper spots in the coating. I will put it back in, and give it a test tomorrow.
