What is the difference when corrugating a ribbon with rounded corrugation vs sharp sawtooth corrugation?
I notice that high end manufacturers don't seem to use sawtooth corrugation much, do they have more resonance due to the flat faces or something?
I would imagine that a sharper edges corrugation would be more difficult to deform into standing waves though.
I ask because I'm CADing up a custom ribbon corrugator to be fabricated and I want to know whether or not it should be pointy or rounded.
Maybe you could pull up images of ribbon tweeters and look at the ribbons to see what's usually done in that respect. Seems like a rounded corrugation might be less likely to fail by fatigue fracture than a pointed corrugation type might.
I would imagine that a sharper edges corrugation would be more difficult to deform into standing waves though.[/QUOTE]
Given equal ribbon weight to either profile, a gut feeling says a more limp sharp edge might actually be prone to increased excitation of its mass than a more rigid
or gently curved ribbon design
Pure speculations on my part though
David
David
I'm just visualizing one of those Chinese paper accordion folding fans. The more rigid the corners, the less they like to bend.
When a sharp bend occurs in aluminum you work harden that edge and now you are prone to a stress fracture along that edge.
If you never moved it again then all would be well , but that isn’t the environment
a ribbon will be working in. You will be stressing it even more and all around this stress point
Just another consideration
The force resulting from the interaction of the current with the magnetic field is always perpendicular to the current flow. If the ribbon has a perfect triangle corrugation the force will be 45 degrees off in either direction depending on the side of the triangle. This was my reasoning for choosing a sinusoidal corrugation.
I haven't done the math but I suspect the mag field forces of triangle vs sinusoidal will sum to the same overall for and aft force , IF both are same pitch and pk to pk dimension.
I thing the force vector acting on the air particles is different in the two versions. Which is better, I don't know.
haven't measured distortion BUT have made varieties of V shaped and rounded corrugations in pitches ranging from approximation 1.5 to 3 mm
I was looking primarily at the resonance that happens roughly between 3 and 10khz depending on corrugation size/ribbon width/ and diaphragm material.
If the pitch/ size of the two corrugation types were the same , the resonances and waterfall looked about the same and the overall freq response was close as well
I didn't see any useful difference between them
I did not do destructive testing on the V shaped ones to see if they failed any sooner than the rounded variety so dont really know about their durability
- Planars & Exotics
- Ribbon corrugation, rounded or pointed?
