Review here:
Scanspeak 10F/8414G10 Discovery 4 inch Fullrange
Cliff's: Really good fullrange driver. Nice on/off-axis response linearity with the apparent breakup pushed out to ~16khz. A mild rise in output on the top end (to help combat the otherwise falling response off-axis) that could be easily flattened via DSP with a shelf filter if one were so inclined. Great usability above 300-500hz for higher output (to help overcome the mid-80's sensitivity). Truly an impressive driver for only $73/each (as of this writing).
