Hey Everyone,
After a long while of enjoying my 2 original Return of Zen amps in seperate systems, I am bringing them together in one room and I would like to create a set of monoblocks. I have been reading the old literature and understand that paralleling the channels is the way to go for increased power. My question is about the resistor R2 at the output of the circuit. If I parallel the channels, does it hurt to just use one 100 ohm resistor? If I parallel the channels with two 100 ohm resistors, 50 ohms would be the result, along with higher power handling. Would it affect the sound, or is it there just to block DC?
Thanks, TikiGod
PS, after looking around here, I might have to break out the soldering iron for a new project....
Thanks, TikiGod
It's just there to take DC out before somebody's relay
kicks or whatever. Also, it often provides some kind of
DC path for the feedback loop in the absence of a load.
Value is not at all critical. I pulled 100 ohms out of a hat.
