hey folks, this is my first recapping, and so far it's all ok, i replaced almost every cap with nichicon and elna caps, but i have a few problems identifying some caps: first of all here they are:
(the blue ones)
(red onees)
(red again)
are these film caps or am i mistaken? Also would anyone recommend me some replacements for these and what kind of specs should i look at - i mean i dealt only with electrolytic ones.
Also i have some doubts about replacing the two black caps above, since they are soldered a bid different here:
i can see that one of the connectors is soldered to these cables, if i replace these caps, i should resolder them like i it was before? I mean - is that solder done on purpose? Thanks
(the blue ones)
(red onees)
(red again)
The red are Wima MKP (popypropylene metallized) 1uF/250V so not bad, the blues are surely also film but can't read the type so I'm not sure, can you post a photo where can read the value & type, about blacks I'm not sure are caps, could you post another photo showing all component & if it's something marked better?
Wima MKP10 is a fine polypropylene film cap. I would not replace them. I think the blue ones are either RIFA or Epcos caps but they could be MKT or MKP.
If they're MKT you could replace them if they are in a critical position. Otherwise I would leave them where they are.
Good luck with desoldering the cables as it won't be very easy with a standard soldering tool. From the pic it looks like lead-free solder. Remove that with desoldering braid and use tin lead solder when resoldering parts. It will be a mechanical better connection.
Controversial: make sure the film caps are orientated the same way when replacing them. So not one in reverse. Despite that they are non polar this is ! The outer foil is marked with the stripe with Wima caps. If that one is connected to the lowest potential that cap is more or less "shielded".
Thank you guys, i managed to replace those 2 big caps
took me about the same amount that it took to replace around 25 regular caps hehe
but i managed, so far everything works great, since this is my first real recapping, i was afraid to turn the damn thing on thinking it could explode or something, but i was listening for about 3-4 hours for a few days, and no problems, and i fixed my channel dissapearance problems i had before
