Thank you Andrew, so I would need to use 4 * 10A diodes in full wave bridge mode to replace this rectifier & retain the same power handling?
Edit: Has anybody got a recommendation for a good, fast, soft recovery 30A diode to be used as rectifier in a digital amp, rectifying PS before input to switching trafo?
