I have a Fluke 45, bought some years ago on ebay.
It worked ok until last month I found that the DC reading were ok if the voltage under measurement is positive.
If it's negative, it display the correct value if the input is limited to the 0 to -3V range.
For values bellow 3V the ralays comute and display "OL".
Of course I can just switch the probes...
I looked at the service manual and proceed with the tests defined (limited to the 3V range) and everything seems ok.
Since I use it only for hobby activities and have no plans to buy a new one, does anyone have a clue about what can be the problem?
In my opinion this is a fine piece of equipment and it's a pitty if I have to put it away.
