Regarding a Toshiba SY335 preamp
After following the advice from Irrebeo and Ian Finch on a Toshiba SC335 power amp, it has been working nicely over the past 10 days or so.
As fate would have it, I came into possession of a companion SY335 preamp. Earlier in the week I encountered someone selling it for the cost of 2 fast food meals. Since it was so cheap I bought it but before parting company with the seller, I was given another SC335 power amp at no charge. For the latter I shall repeat the previous process but it's questions about the preamp that I'm posting about.
I intend to replace all the electrolytic capacitors but while looking for some online opinions of this unit I found several forum threads concerning the 4558 op amp. Changing it for a more modern one was recommended - an NE5532 or (I believe) an OPA2134.
Both are available locally for $1.80 & $4.00 respectively. I can buy both because they are quite cheap but since I would prefer to only remove and replace once, is there a preference of one over the other?
I also read about changing resistors in the phono preamp to 1% metal film of different values. Is that, or changing non-electrolytic capacitors, something worth doing?
Joined 2010
It's good that you are happy with the amplifier and your work on it. The preamp is not a particularly well specced unit though and may well benefit from some minor improvements, if only to the components.
OPA2134 is a JFET input opamp whilst NE5532 is a Bipolar, like the 4558. Any advantage of the JFET type is not likely to realized in the preamp, so it may not make much difference what you use but certainly, 5532 would be good move and at $1.80 is not expensive. If I had a choice, I would avoid the Texas versions though. Digi-key have an On-Semi version that's even cheaper at US 94 cents but that saving may be offset by other costs in your location. Still, that's my pick of standard thru-hole types.
With passive components, it is a good idea to replace carbon film resistor types with metal film, particularly in low signal areas of preamps, where noise is a significant part of the signal. Phono preamps certainly fit that description and you could replace like for like values, expecting at least a small audible improvement in background noise level.
RIAA equalization is a part of phono preamp design and this requires close tolerance R and C components anyway. If your advice is to use different resistor values, I would check that the advice is relevant first. It may mean a change to an old (1976) amendment by IEC to the RIAA standard equalization. That was withdrawn in 2009 due to bass replay problems, so you can't be certain what benefit if any is possible in upgrades without knowing the reason and dates.
Changing capacitor types in circuits involving many caps, can reduce overall distortion by very small amounts but generally, there is little improvement by changing film caps when size is limited by the PCB layout and increased noise proneness. Polypropylene film (MKP) types are popular as a replacement for MKT or greencaps now but size and cost is significantly greater. As a general replacement strategy, its probably not a good idea in a complex preamp. A strategic replacement of a few caps in critical locations might be smarter. However, without a schematic or the prior experience, I would not like to suggest how to proceed with that. You may also get more specific replies and advice in the Analog Line Level forum, when it comes to preamps.
What you say makes sense and coincides with the (AK) thread about revamping one of these. That poster made some extensive changes but proposed that the most significant were changing the op amp and installing same voltage power supply capacitors with 3X the value. At this point my intention is to do likewise plus I think I shall put 1% metal film resistors in the phono section. I believe that coincides with your comment. I won't be changing anything else save for new electrolytics all around with those of the same capacitance but one voltage level higher.
Too bad this preamp is a recent acquisition because I have no knowledge of how it sounds in it's present form. Before I start doing any component swapping, I will hook it up for a day or so just to see if I can notice a difference afterwards. Plus I should find out if it actually does work.
With the cover off, there's a lot of vacant space. The sparseness reminds me a lot of a NAD 1020.
If the preamp works, run it for a few days before doing any serious listening.
The sound will improve with the break-in.
As it sits, in it's unmolested state, it works and sounds OK just needs control and switch cleaning. It will probably be few days before I get the new parts so I'll leave it on in the meantime and listen through it as time allows. Unfortunately my 6 day 80+ hour work weeks will not allow a lot of that.
As I got my SY335 I had it running for a couple of days unchanged. Voltages internally were ok so no immediate need to rescue the PS or anything else.
Short of words, I would say it sounded ok over Aux and tape inputs. The phono stage compared to my little bear t10 was a little bit thin sounding and the highs not very well developed. As that I would have not been happy with it but since I was planning on going through the mentioned (AK) mods I used the time to get a feeling for it.
I started out with the PS upgrade which did not do anything to it that would have been obvious to my ears. Changing the opamp in the line stage made the Aux and tape loops a little bit better but the cap changes did the major trick. I upgraded all electro lytics and substituted the output caps with film.
In the phono stage changing the opamp to NE5532 was helping but not that much to consider it done. Following through with the resistor and cap upgrade inclusive omitting the resistors and caps mentioned on (AK) changed it completely and opened not only the bass region but also the HF up.
I went in both stages with NE5532 since I had these on hand, the Opa were not available locally here and it seems to be ok for me.
After the upgrades done it sounds much better than stock so upgrading is worth it and transforms this little unit from average to pretty good..
So I guess we can conclude that ditching the 3.5-decades-old electrolytics (especially smaller ones of presumed average quality) makes a major difference, with small extra improvements yielded by opamp upgrades (though I'd proceed with caution as the board layout in a late-'70s devices is likely to conform to various definitions of "sucks", and e.g. extra local bypassing may be helpful). Can't say I'm overly surprised there.
Over this past weekend I was able to install the new metal foil resistors, electrolytic capacitors and op amp in the phono section. I posted in the Parts forum a question on two caps indicated as low leakage so I used current standard ones rather than overpay for modern "low noise" ones. I left two of what I believe are carbon film resistors in place (tan colour) because the local shop had no metal film with the right value.
Thinking it would be an interesting option, I installed a socket for the op amp and bought both NE5532 and OPA2134 in case I wanted to compare them. The 5532 went in and there is less noise than there was so I'll leave it alone.
As luck or something would have it, I wound up with yet another one of these pre's along with the power amp for again, next to no money but they're the Aurex branded versions. Since I believe them to be the same internally and I have enough parts left over, I'll replace the same devices - except the op amp. In this case I'll use the OPA2134 and compare both entire preamps.
Sorry to dig this out but did you ever made the comparison?
I also got a second one as Aurex MKII for my bedroom system and went all out with replacing all caps including the ones in the feedback loops of the line stage and phono stage. So all green caps included. That somehow made an additional improvement somehow.
Also here I went with NE5532 but I'm thinking about getting OPA's some day but it would be interesting to hear if you found a difference between NE5532 and OPA.
Several days ago, I replied to your post or so I thought. I was away from home, using my phone but I see my attempt was unsuccessful.
In a word, no I never did get around to swapping op amps. Since I was satisfied with an NE5532, my curiosity was not sufficiently aroused to experiment. A contributing factor is that I have not been spinning much vinyl lately.
My primary source of supply for music has been buying second hand but the selection of used LP's has been in steady decline. At least this is so in the thrift stores I tend to frequent. Prices have risen high enough that I don't thumb through records nearly as often as I used to. Used record stores abound in my area but prices are above what I wish to pay. They're probably where all the good thrift store records wind up.
I have been focusing on CD's instead. Those are still a buck or two each and the selection of interesting titles is far greater. I think people rip their CD's to a hard drive and then dump their hard copies. I have been buying CD titles that were never released on vinyl so am listening to music from the 90's and 2000's that for the most part, passed me by. This change of direction did prompt me to find a CD player (also used) that sounded less obnoxious than those I have or had.
In the future I may install the OPA2134 in one SC335 and do a side by side with another containing an NE5532 but spare time is nearly non existent.
