Rega Saturn in Silver
For Sale : Rega Saturn in perfect working condition. Price :900 Euro
Listed below are new features found exclusively in the Saturn :
Heavy aluminium chassis with 10mm frontplate
Two parallel connected Wolfson WM8740 dual differential Digital to Analogue converters improving the dynamic range and linearity.
The master clock provided by a High stability low jitter crystal oscillator module.
Substantial 60VA toroidal transformer with separate windings for audio, digital & display circuits.
High capacity power supply`s utilising Nichicon Fine Gold audio grade capacitors & fast rectifier diodes.
Digital to Analogue converters utilising Solid Polymer de-cou pling capacitors.
Nichicon Fine gold audio grade capacitors by-passed by Evox film capacitors are employed in the signal path, and in the audio sensitive de-coupling positions in the Digital to Analogue converters
Post DAC analogue amplifier and filter employ a Cascade pair discrete Class A amplifier using low base spreading resistance transistors.
The Post DAC analogue amplifier and filter is supplied from a low impedance supply, giving a tighter & enhanced bass.
Large double-sided PTH PCB with generous ground planes.
These improvements take sound performance far in advance of the already superior level achieved by the Apollo.
