I used silk spun HF-copper-Litz for the rewire of my Rega300 and my DIY-Arm.
7x0.05 or 5x0.05mm^2 is a good choice.
Two of the wires were twisted together which resulted in low enough ohmic value and a even higher flexibility than a single wire design.
Then two strands were twisted together to give one cable for each stereo channel.
The twisting slightly increases the capacitance to ~50pF but also reduces noise sensitivity.
Besides the better looks it results in more 'defined' conditions and values - think about capacitances of wires against PE and against each other, or cross coupling between stereo channels, etc.
The copper litz is quite cheap and easy to source.
If it gives You a better gut feeling, You may even use silver HF-wire, but prizes and sourceability are much worse.
The internal wire ends at the solder pins of the arm connector from where a decent well-shielded cable runs to the preamp, either SE or balanced, depending on the preamp input connector.
It seems quite popular to omit with the arm connector and to extend the arm cable to the preamp input amd some even claim it to be the best way.
I'd like to ask those: "Best? In what regard?"
I doubt that one or two solder joints are audible at all.
I assume one rather can hear other effects of such more doubtful than well done cable design
The ohmic resistance of those thin wires is just high enough to cause a small signal loss when using low output MC pickups.
Hot and cold wires of each channel need to be twisted together at least or well shielded to achieve sufficient noise immunity.
The close proximity of the wires and/or their close proximity to a shield results in increased capacitance, which may give issues with low-inductance MMs like the ATs.
Fixed lengths and cable parameters certainly don't count in for the 'Best'.
And finally will such self-made cablings not show the constancy and consistancy between several samples as even the cheapest professional commercial cables offer.
I can only recommend to change the internal wiring of the arm and to use a proper external cable.
jauu
Calvin
