I wanted to make a photo tour on how i did this job, i already did one speaker from a to z. now the second one an i try to make pictures as much as i can.
First of all i get my aceton ready
[IMGDEAD]http://wrinex.clanteam.com/DSC_0497_001.JPG[/IMGDEAD]
Then poor a huge amount on the mylar so its wett and soaky. then i apply the plastic to prevent the aceton to evaporate in 10 seconds.
then i wait for half an hour and fold the plastic back and swoop sideways, all the wire and allot of the dark crap to one side.
[IMGDEAD]http://wrinex.clanteam.com/DSC_0494_001.JPG[/IMGDEAD]
i remove all the wire, and start all over again, wet it with allot of aceton.
[IMGDEAD]http://wrinex.clanteam.com/DSC_0496_001.JPG[/IMGDEAD]
[IMGDEAD]http://wrinex.clanteam.com/DSC_0498_001.JPG[/IMGDEAD]
and apply the plastic blanket
it will suck to the aceton so almost no air comes to it so it wont evaporate
Then after half an hour, pull back the plastic but not all at once or the glue wil harden again. just 10 cm and clean it with a towel.
[IMGDEAD]http://wrinex.clanteam.com/DSC_0500_001.JPG[/IMGDEAD]
To get the last residue from the mylar soak ur clean piece of tower and rub it, you might have to do this serval times for the corners and some anoying random sticky stuff.
Then when you repeat this till you done the whole thing it looks like this
[IMGDEAD]http://wrinex.clanteam.com/DSC_0502_001.JPG[/IMGDEAD]
Just one thing left the button in the middle of the mylar has to go. get a dril and carefull drill in the middle. BE CAREFULL this is the most tricky part if it is stuck in ur drillbit and the whole button turns around you end up with a huge hole in ur mylar. when the thing is gone that holds the button in place use again allot of aceton and gently try to turn the button till it is off.
[IMGDEAD]http://wrinex.clanteam.com/DSC_0504_001.JPG[/IMGDEAD]
clean it up with aceton and remove the piece of aluminum sticking out.. alll verry gently, its rather easy to screw up ur panel in this stage.
after i cleaned it, i tend to cut out a small piece of tape (clear tape would be better) cut the corners and apply it on the spot with the hole. i do this so it wont get a tear. when i reapply the button i use a hot drill or any other metal to pierce it without any tears. then it looks like this.
[IMGDEAD]http://wrinex.clanteam.com/DSC_0507_001.JPG[/IMGDEAD]
after this i use a paint burner to slightly heat the tape so the wrinkles will be gone. be careful here as well you dont want to heat the mylar around it or it will losen up!!!.
The button is broken, as you can see, i will make a new one from lexan with some filt on one side on my cnc to replace this one.
[IMGDEAD]http://wrinex.clanteam.com/DSC_0508_001.JPG[/IMGDEAD]
thats it for now, i wont bother you with the bass panel, its the same story except it has no button. after that i start the rewire, or in my case refoiling, and i will make some photo's of that as well.
Best regards Joppe
Best regards Joppe
