What would be the best option in rectifier diodes...im a bit sceptical thatr i will hear any differende...(against ordinary diodes in paralell with a small cap to slow the down) but since im doing this amp overly seriosly i think it would be propper to atleast look in to the diod bull**it...;-)
any recomendations ?
/micke
/micke
I've used soft recovery diodes in DACs before and was very pleased with the results. I'm with you on this one however in that I really don't feel it would make a huge difference in an amplifier situation (DACs are particularly noise sensitive). Then again, hang the expense, why not use them anyway.
Pete Fleming
Pete Fleming
Consider using Schottky diodes. They are cheaper than say HexFred's or QuietFred's but only come in about 100V rating. I will use Schottky for the driver stage and probably HexFred's for the power section.
This is a majority carrier diode, and there is thus no reverse recovery.
The Fred's mentioned have soft (reverse) recovery).
Petter
Petter
I agree with NP on fast diodes for high power amps. They don´t offer much in amplifiers. Just use good normal diodes and also take care of the typical precautions in using the correct caps where needed. You will have excellent results.
Given Schottky's lower forward voltage drop, I'd say they
>are< pretty cool! 😉
I've held off using them in power amplifiers because the
100 PIV rating of the units I can easily get is a bit marginal. But I gather that's about to change as new
semiconductor materials become available.
But the ultimate in "cool" are probably syncronous rectifiers. Dunno how they rate for noise characteristics.
(In case you're wondering, this is just a power transistor
with its base/gate wired to a low voltage winding that forces it into saturation--it thus acts like a rectifier.
A bit too busy for our purposes, but an interesting idea that might be worth exploring some day.)
>are< pretty cool! 😉
but isnt 100V enough safty margin? ...in my aleph they will never se more than 48v and that is peak to peak value..
Is there any preferable brand among Schottskys? and what spec are inportant when used in rectyfiers?
/micke
/micke
nice...but those suckers are about 10$ a piece here in sweden...and that is in 25pcs quantites...(farnell.com)
any cheaper advice?
/micke
any cheaper advice?
/micke
Damon, the best thing about sync rectifiers is that it's possible to give them soft recovery characteristics too. Hmm, maybe some food for thought 🙂
Pete Fleming
Pete Fleming
- rectifying....what would be prefered (aleph PS)
