I'm adding a choke to my STF champ clone (has a way oversized output transformer and a bit extra filter capcitance) and later may add a second 6V6.
It's got a 5Y3 right now. I might even put a solid state bridge on a tube base... But what I'd really like is a better rectifier tube with a bit more voltage (less voltage drop) and more current capability, assuming such a thing exists.
How about a 5V4GA? What size choke are you getting, and are you using a CLC after the rectifier tube?
http://www.mif.pg.gda.pl/homepages/frank/sheets/093/5/5V4GA.pdf
jeff
jeff
I'm not exactly after less sag (or I would beef up the power transformer and go to solid-state rectifiers), just less loss and a bit more current at the rectifier, so that I can add better filtering and a bit more current storage.
STI makes a "super-duper" (my words...they call it Deluxe or a SuperCharged but that has other fender connotations of push/pull, which it's not) kit similar to what my entry-level kit is evolving into (two parallel 6V6 single-ended), except mine will have an even bigger output transformer and theirs has two rectifier tubes. I'm trying to get away with the same power transformer initially, so it will have a LOT of "sag" when I push it hard. But I'm adding chokes and caps, so it might be pleasantly clean and even 'chimey' at lower volumes.
jeff
yep, that was the idea, still a smallish cap at the rectifier, then a larger one after the choke. So hopefully no in-rush at start-up. I'll model it first, of course.
Google GZ34/5AR4 swap for 5Y3.
Thanks, I will do that also.
- Live Sound
- Instruments and Amps
- rectifier tube recommendation for champ clone
