Hi All,
I am seeking replacement woofers for my Mackie HR824 studio monitors. The originals are Vifa P22WP-01 8" woofers and are no longer available to buy so I would like your advice on any woofers that may have the same or very similar specs.
I am not familiar with the below technical specs and their meaning so the below information will probably make sense to a lot of you.
Below are the speaker specs of the woofers:
TS: Fs 29.5Hz,
QMS 2.20,
QES 0.31,
QTS 0.27,
Vas 77 l,
Re 5.8 ohms,
Sd 235 cm2,
Rm 2.5,
Bl 10.2,
Md 29.5 g,
Xmax 6 mm
Any assistance would be greatly appreciated as these are my most prized posessions and I would like to continue using them for many many more years
TS: Fs 29.5Hz,
QMS 2.20,
QES 0.31,
QTS 0.27,
Vas 77 l,
Re 5.8 ohms,
Sd 235 cm2,
Rm 2.5,
Bl 10.2,
Md 29.5 g,
Xmax 6 mm
