Recommend a good UK speaker cabinet maker
Can anyone suggest a decent cabinet maker here in the UK for a pair of bookshelf speakers?
Maybe a member here has the skills and kit.
The build will be either a small full range Jordan Eikona or a two way using Scanspeak and Morel drivers.
I would like the front baffle made from Corian or Silestone type material if anyone can also recommend a company that will CNC small jobs.
Corian is cut using normal tct router bits, and sanded with wet and dry paper, finishing with "barkeepers friend". (it's also fairly easily repaired). Silestone is a quartz/resin material which in reality can only be machined by a proper stonemason's shop, needs diamond cutting and polishing. I've no idea as to the suitability of either as a baffle. I imagine corian would be good, silestone could have difficult resonances, but I've never seen it
