R25 smokes in tse 300b
My TSE sat Idle for some years because I was having issues with it and and only now getting back to get it running again.
this TSE is setup for 300b tubes.
I powered up with just a rectifier.
b+ 440
b- -175
After some a few min. R25 smokes. I replaced R25 and R14.
Figured I should start out with the proper checkout steps.
Filament voltages were 4.95 each
again b+ 440, b- -175
Grid of right output tube is -58
Grid of left output tube is +350 and slowly climbing
With rectifier in after a few min. r25 starts to smoke again.
I measured across r25 and getting over 600 volts.
So, where do I go from here?
