I've had my SSE up and running for a few days now and all is going very well.
I'm about to order some CL90 inrush resistors from the US as no one in the UK has them and I want to get a few other bits along with those.
I've been reading Georges simulations on the Tubes and Transformers page but I'm not sure if I've understood it correctly and I don't want to order the wrong parts.
I'm running Tung Sol 6L6GC STR and some Svetlana KT88 tubes and I'd like to get corresponding resistors for each.
My Power transformer is the Edcor XPWR059 and opt's are CXSE 25-8-5k (5000k load?).
For the 6L6's, with a b+ of 450v I'm looking at a resistor value range of 430 to 680, is that correct?
And for the KT88's, same b+ I believe I'm looking at a range of 330 to 560?
If I'm right so far (and its from here I'm a bit lost) how do I select resistors within that range?
Also, if its advisable to gather a range of resistors to future proof my tweaking is there any suggested recommendations? I don't have the space to rig up a rknize style resistor selector switch but I have mounted everything in such a way as to make the resistors easily accessible and only 5 minutes to change.
