If the relay is engaged and there is audio on that bussbar, the relay is defective, there is a bad solder connection on the relay, there is a break between the bussbar and the relay or there is a break between the relay and the speaker terminals.
If you connect a speaker to the speaker terminals and there is audio on both the positive and negative speaker terminals, there is a bad connection on the negative speaker terminal.
- General Interest
- Car Audio
- quick question
